Update to Firmware 1.2.0
nospam
Posted: 13.10.2022 17:29
Modified: 18.05.2024 03:50
I wanted to report the following Problem:
Got the Update Message for Firmware 1.2.0:
- Update did NOT work on Android (Pixel 5).
- Update did work on an older iPhone without Problems.Question: Are there any patch notes on the update? What are the changes?
Posted: 13.10.2022 17:35
Hello
Thank you for your comments and glad to know the Aranet4 could be updated with another device.
You can find the changes on our page https://forum.aranet.com/all-about-aranet4/aranet4-with-firmware-v.1.2.0-or-greater-integration-notes/ on this forum.
nospam
Posted: 13.10.2022 17:45
Okay thanks!
Just mentioning: Overall the App seems a lot more stable on iPhone compared to Android.
I have to restart the App quite a lot on Android because of connection issues.Would be great if this can be improved. (I currently use 3 Aranet Devices. Love them. ;-))
salty_wookie
Posted: 01.11.2022 08:09
When trying to update my firmware (Aranet4 Home) I'm getting a msg saying my device with v1.1.1 is up to date. Like the OP I also have a Pixel 5 so not sure if there is an issue causing this? Or is 1.2.0 not the most recent firmware for the Aranet4 Home?
Posted: 01.11.2022 09:30
Hello Salty_wookie,
Thank you, please try to update your Aranet4 by using another smartphone,
salty_wookie
Posted: 02.11.2022 08:45
Same issue one my Pixel 1 XL. Not sure if there is something common between these phones that would cause this issue?
Posted: 02.11.2022 09:11
Hello Salty_wookie,
Although version 1.2.0 is the most recent one, it might be the case that your device hasn't had the need to be upgrade yet. Please check this page: https://support.google.com/pixel/answer/7550416?hl=en to see your Android version in the Pixel 1 XL and upgrade if necessary. Then try again to update the Aranet4's firmware but if you can't then your device doesn't need to be upgraded yet.
