Aranet4 Incorrect Temperature
robboyle
Posted: 09.07.2021 01:16
Modified: 15.12.2025 10:13
Just unboxed my Aranet4 and the temperture is clearly incorrect. It's reading 83F which is way too hot - my smart thermostat reports 73 which I believe to be correct.
Is there a way to calibrate the temperature, or do I have a faulty unit?
Posted: 15.07.2021 10:42
Modified: 03.12.2021 09:35
Dear robboyle,
Your question is forwarded to Aranet support team. You will be contacted.
rhinochaser
Posted: 02.12.2021 21:02
I'm having the same issue. Showing a good 20 degree F hotter than actual temp outside. I also had an issue with CO2 calibration. New out of the box it would not read much lower than 500 ppm outside. I did manual calibration, which I guess resets outside air to 420 ppm, but what if actual outdoor ppm is 450 ppm based upon that third-party link to current outdoor air CO2 levels?
Do I actually not really care what the actual outdoor air CO2 baseline is, since what I should care about is increase from baseline, since most metrics for actions are framed assuming outdoor air or 400 or 420 ppm?
Posted: 03.12.2021 09:35
Hi rhinochaser,
Aranet4 sensors are factory calibrated against 0 ppm CO2. When calibrating the device manually against outdoor air, it is assumed that the normal CO2 level is 420 ppm. To be sure about Aranet4 measurements you can compare its CO2 outdoor measurement after calibration with the third-party services data, f.e. mentioned in this topic: https://forum.aranet.com/all-about-aranet4/how-can-i-calibrate-my-aranet4/
robboyle
Posted: 31.07.2021 20:34
For future reference, I ended up just having to wait - over a period of a couple days, the temperature reading slowing came down until it was in line with my other thermometers.
ronnie
Posted: 02.12.2024 18:55
I have the Aranet 4 Pro and temperature is constantly overestimating by approx 5-6°C. At this point, I'm not even sure the humidity works either as outside on cloudy, humidity and rainy conditions it gives a 38% reading. I hope at least the CO2 is correct, otherwise this device goes back to where it came from.
Can you please advise?
Posted: 03.12.2024 15:29
How long have you had the device for? And can you send the Serial number of the Aranet4 to support@aranet.com or just in an answer here.
bimbam
Posted: 04.12.2024 22:54
You can adjust this now to 424 or even 425 ppm.
Trends in CO2 - NOAA Global Monitoring Laboratory
jwnn
Posted: 20.02.2025 13:07
For a project, we have installed 10 Aranet 4 sensors.
These sensors were selected to monitor CO₂ levels in multiple cinema halls.
While the CO₂ readings appear to be accurate, all sensors show discrepancies in temperature measurements within the rooms.
The temperature readings from the Aranet 4 sensors are used for temperature control of the AHU units.
Below, you will find a list of measured values, showing both the readings from the Aranet 4 sensors and those from a calibrated sensor.
paul_hammant
Posted: 15.07.2025 09:10
I've two Aranet4 sensors. They are close enough on CO2, but 1.5 degrees C different on temp :(
I just bought a pack of three bluetooth Thermometer/Hygrometer sensors with data logging export. They agree with each other on temp, and are close enough to one of the Aranet4s, but not the other. What should I do to make the two Aranet4 units agree on temperature? I can supply a photo or video if needed.
Posted: 15.07.2025 13:00
Hello!
What are the Thermometer/Hygrometer sensors? And is it possible for you to send the data over to support@aranet.com?
