CO2 Y axis ppm range
zeolite
Posted: 05.05.2021 04:25
Modified: 15.12.2025 14:42
I have been using the Aranet4 to monitor room CO2 and the units on the Y axis were between 0 ppm and 1500 ppm if I recall. I then used the device to monitor CO2 levels behind various Covid face shield designs which resulted in spikes to 4000 ppm.
Now when I go back to monitoring room CO2 between 500 ppm and 1400 ppm there is not enough detail because the Y axis ranges from 0 ppm to 4000 ppm. How do I clear the app data and start monitoring afresh again with a smaller ppm range on the Y axis?
Posted: 05.05.2021 06:18
To clear application data uninstall it and then install again. You will need also to pair Aranet4 back to application.
lll
Posted: 24.09.2021 06:02
It would be great to adjust Y scale to the current X zoom.
Android app "Libra" does it fine, you can check it for inspiration. When you slide X, the scale of Y automatically adjust.
Posted: 24.09.2021 06:45
Thank you for the suggestion. This feature is added to the list of future improvements.
