Does Aranet4 support IFTTT service?
Posted: 02.07.2020 17:33
Modified: 06.04.2025 11:00
No, currently Aranet4 does not support IFTTT.
For DIY integrations using Bluetooth Low Energy please check the following applications that are created by 3rd party developers:
Aranet4 Python client and library (compatible only with Linux)
Progressive web app which supports Aranet4 using Web Bluetooth APIandyro
Posted: 13.02.2021 20:39
We just installed a an ERV in our home. There is an optional aux. control wiring that would let us set a 'carnk timer' or a 'virtual crank timer' that can get triggered anytime CO2 is over 1,000. Are there any plans to add IFTTT functionality, since we could then use the ARANET4 to send the trigger to a smart switch, setting IF CO2>1000ppm, THEN Switch On, (turning ERV to hi-speed) then a second IF CO2<1000ppm THEN Switch Off (setting ERV back to lo-speed). I'm not sure how easy it is to modify the python scripts with OTS smart switches....
Posted: 14.02.2021 00:03
Modified: 14.02.2021 00:08
Thanks for Your interest in our product.
IFTT support is noted in our product improvement feature list and it will be considered in future product development.
