Is it possible to change the setting of the buzzer?
bartn
Posted: 25.11.2021 16:44
Modified: 18.01.2025 05:22
Is it possible to change the setting of the buzzer? So that you can choose at which limit the buzzer starts working
Thank You
bartn
Posted: 25.11.2021 16:47
Yes, it is possible. Aranet4 buzzer works when CO2 measurement value crosses the HIGH level threshold. You can configure CUSTOM CO2 INDICATION MODE in Aranet4 app, as described in adjacent topic: https://forum.aranet.com/all-about-aranet4/is-it-possible-to-change-color-indication-threshold-levels-for-co2-measurements/
tiho
Posted: 06.01.2022 15:19
What about the way it buzzes? It only beeps once everytime a measurement is made but on a workfloor people won't even hear such a small beep. We also have other devices that normally beep or make similar noises. It would be better if for example it would shortly beep 3x on each measurement or even continuously after a certain threshold.
Posted: 06.01.2022 15:57
You can configure the buzzer to sound at every measurement which is higher than HIGH level threshold:
