Protective case for monitor to stay in while measuring
epi
Posted: 25.12.2021 12:19
Modified: 15.12.2025 04:08
I'm one of those parents who wants to send kids to school with a CO2 monitor, but school hadn't allowed it yet. I'm looking for a protective case that the monitor can stay in while measuring, like the homemade 3d printed case that was in the US newspaper coverage of these devices. Ideally it would attach to backpack or lunchbox handle so kids could have it with them in the classroom.
Posted: 27.12.2021 06:38
Dear epi,
As soon as the file for 3D printing is available for sharing, it will be published on our site or this forum. Please subscribe to Aranet news and you will be informed.
Meanwhile, you can look at alternative offers: https://forum.aranet.com/all-about-aranet4/travel-case-for-aranet4/
nushka
Posted: 12.02.2022 01:51
This is a sturdy case that is the same size as the Aranet4 box, except that the corners are round. I haven't done it yet, but the foam that's in the box can be trimmed at the corners to fit the case and immobilize the Aranet4 in the case.
https://www.amazon.ca/gp/product/B077CT7YCN/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
Geekria UltraShell Case Compatible with Bose SoundLink Micro Small Portable Bluetooth Speaker, Protective Hard Shell
Posted: 01.03.2022 09:06
Modified: 22.04.2022 07:06
Please find information about Aranet4 protection case 3-D printing: https://aranet.com/print-out-your-own-aranet4-3d-cover-case/
sunnygal
Posted: 21.04.2022 22:55
Could someone @aranet-techsupport update the link to 3-D printing protective case information? Visiting it now redirects to aranet.com homepage. Thank you.
Posted: 22.04.2022 07:08
Thank you for reporting! The link is corrected.
lowco2fan
Posted: 07.05.2022 17:56
Hello, I am not sure if the problem is on my end or if there is a problem with the model in the STL file. I had the parts printed for me at a library and while the main housing seems to be a proper fit, the front cover doesn't appear to be correct. If I align the top cover with the top side of the main housing, the screw holes at the top are lined up, as is the square cut-out/window for the Aranet4's display.
However, the length of the top cover is too short and the bottom screw holes don't line up. The nut wedges are also inappropriately sized (too long - not the same as too wide, i.e. I don't need to lightly file the sides). Lastly, while the M4 screws I have thread nicely into the main housing, they appear slightly too large in diameter for the top cover as printed.
Is it a matter of the top cover being scaled incorrectly during printing, and I need it to be printed a little bit longer, yet shorter for the cover and the wedges to fit? What should the actual dimensions be in mm for the cover and/or nut wedges?
Thank you.
(The CO2 reading is very high because I was basically breathing directly on the unit while trying to take a photo in my office at home.)
Posted: 09.05.2022 09:29
It has been noticed that a similar scaling difference appears when printing both details at once. Our advice is to print the details one by one. And keep in mind configuring "global" shrinkage compensation of +0.6% for PLA and ABS materials.
