Where should I place the Aranet4 device in the room?
Posted: 02.07.2020 14:11
Modified: 06.04.2026 10:58
Aranet4 sensor can be used to measure air quality in places such as your bedroom or living room, kid’s room, workspace, classroom, conference room, café, concert hall, museum or any other indoor area which you would like to know the air quality of.
Aranet4 can be placed anywhere in the room where you tend to spend a lot of time in – on a surface, or mounted on the wall where it can be comfortably seen. Since people and animals exhale CO2 the readings can be momentarily higher if you breathe directly on the sensor so holding the sensor in your hand can sometimes give a higher measurement. However placing the sensor near a window or entrance door might give a slightly lower reading because of the airflow in these areas.
Aranet4 should not be placed in direct sunlight or in areas with a risk of splashing the sensor with different liquids, or high-humidity environments (higher than 85%) such as your bathroom. Place the sensor in a safe place where it cannot accidentally be dropped because it isn’t drop-proof.
