Can new Aranet Gateway Pro be used as repeater for main base station
viteocmed
Posted: 10.06.2026 08:45
Modified: 30.11.2026 02:42
Can Aranet Gateway Pro be used as repeater or direct write data to main Base Station, to have all data in one Base station without using the cloud?
Posted: 10.06.2026 09:38
Aranet Gateway Pro can't be used as a repeater or to directly write data to the main Base Station.
First, it is not possible to connect the same sensors to two base stations; for this, you need another Pro Plus Base Station and a backup file (from the main Base Station), which should be uploaded so the Base Station receives the data from the same sensors as the main Base Station does.viteocmed
Posted: 10.06.2026 09:55
I need all data in one station
Posted: 10.06.2026 12:02
Short answer is: Impossible.
It is impossible to have data from different base stations in one.
You can not send the data from one base station to another; a base station can only receive data and send it to the Cloud.
If sensors are too far (data gaps or no data), then another (duplicated) base station can be installed with the same configuration. Data will duplicate because of the same configuration and data gathering from the same sensors within the range. The only option to have data in one place is by using Aranet Cloud, where duplicated data will be sorted out.
To get the data from all the sensors around, you can try to relocate the base station.viteocmed
Posted: 10.06.2026 13:09
Modified: 10.06.2026 13:09
We are using it like that right now, but will be greate if will be available sincronization of the data between the stations.
Posted: 10.06.2026 13:19
We will add this to our feature review list for further discussion with the R&D team and consider the possibility of synchronizing the data of multiple base stations.
