connecting Optic IR pulse reader to pulse transmitter
alexziller
Posted: 12.01.2025 21:47
Modified: 30.03.2026 17:38
Hello!
I wonder if the Aranet dry pulse counter can be connected to a IR Infrared IEC62056 IEC1107 optical probe like this for reading modern gas meters and broadcast the measurements to a base station. The optical probe is powered via usb.. but one wire (Yellow).should be for data transmissionThanks in advance.
AZ
Posted: 13.01.2025 06:11
Modified: 03.06.2025 13:09
As long as the pulse provider can provide pulses in these parameters then, yes:https://assets.aranet.com/documents/Aranet_Datasheet_TDSPIC02_Dry_Contact_Pulse_counter.pdf
- Maximum pulse frequency 25 Hz
- Minimum pulse width 10 ms
- Minimum interval between pulses 30 ms
