How to get the latest firmware version for the Aranet PRO base station?
Posted: 19.01.2021 20:59
Modified: 30.03.2026 07:10
You can visit https://aranet.com/en/pro/downloads, and you will be able to find and download the latest firmware version. This file should be unzipped and then uploaded in the format AranetProUpgrade-vX.X.X.tar.gz to the Aranet PRO base station. Don't rename the firmware file!
Firmware upgrading instructions
1. Download the firmware zip-packed archive file at https://aranet.com/downloads to your computer.
2. Unpack the zip archive to the folder you are able to access.
Don't change the file name!
3. Turn on Aranet Pro base station and wait for the system to load.
4. Log in to Aranet Pro web interface as a user having Administrator rights.
5. Navigate to SYSTEM menu and select FIRMWARE tab.
6. Click on CHOSE FIRMWARE FILE button.
7. In the opened window, find the folder where you unpacked the firmware file, select this file, and click "Open" button.
8. Enter the Administrator password when asked and press OK.
9. The file uploading process will start.
10. When the uploading and installing process is finished, a notification message is displayed,d and the device reboots.
11. Wait about 2 minutes and reload the browser window.
12. Navigate to SYSTEM menu, FIRMWARE tab, and check the firmware version.*****************************
TroubleshootingIf the firmware upgrade fails, check the firmware file name and extension:
- File name must be "AranetProUpgrade-vX.X.X", where X.X.X is the version number;
- File extension must be ".tar.gz".
Some archiver software tends to unpack all available archive levels of the file. Switch off this archiver's feature to leave the archived .gz file untouched.
For example, macOS users should deselect the "Keep expanding if possible" feature of the built-in archiver.If upgrading still fails, contact support@aranet.com.
selecta
Posted: 20.07.2024 12:31
hi i last updated the pro base sation firmware to version in april 4.3.2 and today in july i have updated to version 4.4.4 but on updating, the computer showed current version to be 4.3.7 of which i have never updated, how did it come to be like that am i being hacked? when was that version released? and how long do you take to release new versions of base station firmware
Posted: 22.07.2024 06:12
Please contact support@aranet.com on further details.
