Is there a simple means of increasing the data transmission rate for 3rd party sensors or sending packets of information?
imo
Posted: 06.06.2023 09:08
Modified: 30.03.2026 20:21
I would like to use an Aranet 4-20 mA transmitter with 24 VDC power supply for a 3rd party sensor, ideally I would like to see data every second but it would be acceptable if updates occured every minute. Is this something that is possible with the Aranet system now or a potential future development?
Posted: 06.06.2023 10:19
Hi Imo!
Let me clarify:
Do you want to know if Aranet is planning to add the possibility to set up the Measurement interval to 1 second?
Now the Measurement interval could be set up to 1, 2, 5, and 10 minutes.imo
Posted: 06.06.2023 11:35
Yes since the 4-20mA transmitter isn't limited by battery life when it is powered. But if this isn't possible, could Aranet collect the data over a 1 minute interval in a packet and send this via wifi to the base station to be "opened" ?
Posted: 08.06.2023 09:39
Hi Imo!
First of all, the connection between a base and a sensor does not use Wi-Fi but another technology.Let me clarify:
Do you mean you want a sensor to be able to collect data some time without connection to the base and send all collected data to the base after the connection is restored? This is not the same as in the first message.The 1-second measurement interval, for now, is not a priority feature for an implementation.
