Sample Intervals and Response Time?
qfive
Posted: 01.02.2024 14:30
Modified: 30.03.2026 17:33
Using Aranet T/RH Probes:
- What is the shortest time interval (or resolution) that readings can be taken?
- What is the response time to Temp / RH changes?
Example: For a 1 minute period, how many sample readings can I take? If the RH changes by 20% during this period, how quickly will that change be reflected in the readings?
Best,
Posted: 01.02.2024 14:47
Modified: 03.06.2025 13:06
Most of the information is available in the datasheet here:
https://assets.aranet.com/documents/Aranet_Datasheet_TDSPT309_TRH_probe.pdf
The shortest measurement interval available is 1 minute.
The response time for Temperature change is 10 minutes.qfive
Posted: 01.02.2024 15:19
Thank you.
Response time is typically change/period so for instance 0.2°c/second or presented as a curve if non-linear. Do you know what that is for temp?
Best,
Posted: 02.02.2024 11:06
Sorry, I was looking at the incorrect datasheet before.
The response time τ for the T and RH is unknown for now. We will see if we can get that value for you.qfive
Posted: 02.02.2024 12:15
Great. Thank you.
qfive
Posted: 02.02.2024 12:19
Your return policy states that the product must be unused and is limited to US$750. Am I correct then that we cannot purchase a base + two probes, test them to see how well they work, and then return them if they do not perform as we need?
Best,
Posted: 02.02.2024 12:28
You should contact SalesSupport@saftehnika.com with this inquiry. They might be able to help you with this.
