Base station offline alarms
Posted: 30.05.2023 12:26
Modified: 30.03.2026 21:00
A new built-in alarm rule is available. The base station offline alarm rule will check the connectivity of bases and when offline will be detected, the alarm will be turned on. By default, only a warning is enabled, but a critical threshold can be configured as well.
This option could be found in Alarm -> Rules section.
By clicking on Base station offline the information window is opened.
By clicking EDIT RULE you can edit Warning and Critical thresholds.
