SMS notification
pnfribeiro
Posted: 04.09.2025 12:02
Modified: 30.03.2026 19:56
2 questions:
Is there in the roadmap of Aranet Cloud development the funcionality for SMS notification for any user created rule?
In our case it is important because if there is an alarm when wharegouse is closed (night or weekends) we are not reading mails so often...
Or can you suggest any other solution to achieve de same result?
(based in Aranet Cloud data)
Other problem is when longer power failures happen... T anf T/H probes don't have internal memory so there is data loss (some months ago we had 12 hour general power failure in Spain and Portugal). I can prevent this?
Thanks,
Posted: 04.09.2025 13:18
Hello!
Currently you can configure SMS sending for crossing thresholds in the base station:
https://forum.aranet.com/aranet-bases-sensors/how-can-one-enable-sms-or-e-mail-notification-sending-for-multiple-recipients-from-aranet-pro-base-station/
However the Cloud only supports sms for Base station offline alarms. And currently there are no plans to extend this feature.
If you are experiencing power loss to the base station then I recommend getting another power supply for the base station. A battery or generator.
pnfribeiro
Posted: 04.09.2025 15:41
Thanks for your quick answer.
I think that managing rules in both platforms (base station and cloud) is making these tasks harder than it is supposed to be. So we only use Cloud.
Of course i can make an outside solution using the API to ask Aranet Cloud current alarms avery minute or so... but i don't like that approach.
I hope in the near future you can extend Aranet Cloud with SMS sending for any notification user want to configure. Even if it's a paid service (business oportunity!!!).
Or, wider solution, create automation possibilities in Aranet Cloud (mqtt, IFTTT, API invokation, etc...) like in the base station so we can connect, for example, to a SMS gateway provider!... Just some ideas.
(for example, take a look to Notification Center App in Qnap NAS OS)
