App refresh accuracy
ara4ggg3
Posted: 10.07.2025 20:31
Modified: 30.03.2026 20:39
Is forcing the app to refresh accurate for CO2 readings? How accurate are other readings? I walk around my home to see if CO2 levels level out. Is refreshing every 5-10 seconds when moving from room to room accurate? I couldn’t find info in the manual or FAQ.
Posted: 11.07.2025 05:18
Yes, it measures with the same accuracy as the regular readings. The accuracy can be found in the datasheet here:
https://assets.aranet.com/documents/Aranet_Datasheet_TDSPC0H3_Aranet4_HOME_Z5oT3mT.pdf
