Can the Aranet Gateway PRO 50 be used with Aranet 4 Home Sensor
r3t0
Posted: 27.02.2025 17:56
Modified: 29.03.2026 19:36
I have 4 Aranet Home Sensors at my Home. The Bluetooth reception is so so.
Would it be possible to use an Aranet Gateway PRO 50 with these or what exactly would prevent that?Thanks.
viteocmed
Posted: 27.02.2025 18:30
You can't use Aranet Base Station with Aranet Home sensors, because base station works on Aranet Radio, than works in the subgigahertz ISM 868/920 MHz frequency band and uses LoRa modulation technology.
Aranet Home sensors only work with bluetooth tehnology.
Aranet Pro sensors use both LoRa and Bluetooth.
r3t0
Posted: 27.02.2025 18:44
Thanks. A pitty there's no home station for the home version.
