Is this an Aranet4 PRO or HOME?
pyxelr
Posted: 03.03.2026 16:55
Modified: 30.03.2026 10:43
Hi everyone,
I just received two Aranet4 units that I ordered as PRO models, but I’m trying to verify if I actually got what I paid for.
The labels on the boxes (as well as in the unit itself behind batteries) show M/N: TDSPC2H3.012. Based on some documentation I've seen, the PRO model is usually TDSPC203.012.
Before I ship these back to the retailer, I wanted to check with the community:
Is the "H" in the model number a definitive indicator of the "Home" version?
Physical Cues: Is there a specific marking on the device itself (behind the batteries or on the back casing) that distinguishes the PRO from the HOME?
App/Software: If I pair them with the Aranet4 app, is there a specific menu or "Pro-only" feature (like Aranet Cloud integration or sensor calibration settings) that will confirm the model type for sure?
I’d hate to return these if Aranet just updated their numbering system, but I would like the PRO features for my setup.
Thanks for the help!
Posted: 04.03.2026 06:10
Yes, the sensors are Home versions based on the M/N. No specific physical cues can be used to distinguish the PRO and Home versions.And no, the Aranet Home app is the same for the PRO and Home versions. The only difference in those is that the PRO version has a radio transciever that can connect to our PRO base stations.
So if you are not going to be using the PRO base station, then the Home versions are for you.
If you want to return the sensors, please fill the form here: https://rma.aranet.com/
