pairing problem new motorola phone android 15
ger
Posted: 20.02.2025 20:10
Modified: 30.03.2026 05:33
Good day, i have a new phone : motorola edge 50 neo /Android 15 on which i installed the aranet home app v3.7.9. When opening the app for the first time: the app indicates that bleutooth looks like not enabled (while in reality bleutooth is on) and the app shows a button to divert to bleutooth settings. When pressed nothing happens so it looks like app is not able to open bleutooth. Position is enabled. But when attempting to connect to +add new device noting happens.
Aranet4 home sensor =serial nr 381121002746 REV 6 Bluetooth range= normal software version V1.4.19
Don't suspect the problem to be in the sensor however as when i removed the app and reinstalled same on my old phone, i can still connect to the sensor without problems. Same for my older android tablet.
Any ideas , Thanks in advance
Posted: 21.02.2025 06:22
Hi! Could you please send this to support@aranet.com they will try and help you there.
aranet4_inthehouse
Posted: 06.11.2025 15:17
Hi Ger,
I have the same problem you have.
Is it solved, and if so, how?
Thanks in advance
