Rechargeable Battery Status
kylemcdonald
Posted: 19.07.2024 22:07
Modified: 30.03.2026 15:56
Hi, I have been using my Aranet4 for two years with 2800mAh NiMH rechargeable batteries. I noticed that even when the batteries are fully charged, the Aranet4 shows that the batteries are not full. Is it possible that the Aranet4 is simply measuring the voltage of the battery, and showing low-battery warning because NiMH batteries tend to have the same voltage at 100% as alkaline batteries do at 50-60%?
Would it be possible to get a firmware update that exposes a rechargeable/non-rechargeable switch so that the battery status can be displayed correctly?
Posted: 22.07.2024 08:39
Modified: 11.06.2025 06:08
Thank you for using Aranet and for the valuable feedback!
The usage of rechargeable batteries has not been prioritized as the product was designed for extended battery life using Alkaline or Lithium batteries. Still, the feature request has been internally registered and will be evaluated.
bimbam
Posted: 26.07.2024 13:18
What sense does it make to use rechargeable batteries, when battery life is about 3 years?
You will have trouble with self-dicharge and frequent re-charging and in the end there are no savings or even more costs than with normal batteries.ben
Posted: 12.11.2024 09:14
The Vara Industrial Pro Alkaline batteries that came with my Aranet4 device are about to expire and I was search the forum to learn about the requirements for the replacement battery. The only hint I found is the reply from Aranet above.
I'm also thinking to replace them with Eneloops NiMH rechargeable batteries I have plentyful at hand vs. bying dedicated hiqh quality single-use stuff.
I want to disagree with the previous position that this is necessarily a bad idea: a) do i.e. Eneloops have a very low self-discharge (30% over 10 years!) nor does b) is in more active use cases (2min internval, BT enabled, extended range, frequent history readouts) the actual lifespan reach anything like 2 years. Still an impressive lifespan, but IMHO worth considering rechargeable batteries.
dgt070
Posted: 07.04.2025 04:07
Absolutely love the idea of showing correct charge level for rechargeable AA batteries (re-use is good).
Though I haven't seen any device that implements this feature. Can someone give an example of a device where it's been implemented?
bimbam
Posted: 11.04.2025 12:46
Modified: 11.04.2025 12:48
Eneloops NiMH rechargeable AA batteries, 8pcs 30 €. 1 pc 3,75€
Aldi Alkaline AA batteries, 10 pcs 1,70 € 1 pc 0,17 €
The eneloop solution is 22 times (2100%) more expensive, charger and charging costs not even considered.
How long do you and the Aranet device have to live until you enjoy any savings?
janise
Posted: 29.06.2025 08:17
The thread is about incorrect battery status for people that have inserted rechargeable battery for whatever reason.
For example, because they last longer in cold weather, they are more environment friendly, they are plentyful at hand, whatever. The fact is that people use them and that the battery status fails.
