There is an error message on the Aranet4 screen. What does it mean?
Posted: 02.07.2020 14:46
Modified: 30.03.2026 19:44
There are three kinds of error messages that can appear on the screen of the device:
Error Code
Cause
Solution
0x8001 – 0x8005
The CO2 sensor is damaged
Fill out the RMA form
0x8106, 0x800E – 0xFFFE
CO2 sensor malfunction or CO2 measurement is out of range, caused by:
- Excessive CO2 concentration near the device
- Excessive moisture near the device
-Incorrect calibration of CO2 sensor
- Damaged CO2 sensor
1. Let the Aranet4 device dry completely
2. Manually recalibrate the CO2 sensor
3. If the problem persists, fill out the RMA form
0ppm or 9999ppm
The CO2 sensor is misadjusted or damaged
1. Manually recalibrate the CO2 sensor
2. If the problem persists, fill out the RMA form
kelvinward
Posted: 05.06.2022 07:37
I have an error message on my Aranet4 "Error 0x8002"
I have taken the batteries out, replaced and then re-calibrated the device. It started to work for a short time only to quickly go back to displaying the error messgae.
Can you please advise on what I should do.
I am not aware that there has been any damage to the device.
Thanks
Kelvin Ward
kelvinward@pm.me
Posted: 06.06.2022 05:05
Hi Kelvin,
Your sensor needs repair, please fill out RMA form: https://rma.aranet.com/
ckent
Posted: 05.12.2023 22:32
Hi @aranet-techsupport
I saw your reply to Kelvin, but I only get this error once a day, maybe once a week. It immediately returns to normal operation after a few minutes, at the next cycle. Does your instruction apply to me too? It's also Error 0x8002.
Posted: 06.12.2023 06:17
Hi ckent!
This forum post explains the steps that need to be taken:
https://forum.aranet.com/all-about-aranet4/error-codes-on-aranet4-display/
First make a manual calibration of the co2 sensors. If the error keeps coming back after it, then it is faulty and probably needs an RMA.
