Within spec?
wlk
Posted: 27.02.2024 14:38
Modified: 30.03.2026 18:22
I purchased three Aranet 2 Home sensors to measure the temperature and humidity on each floor of my house. I initially set them up side-by-side and watched them operate over the course of a week. During this time, the temperature readings of the three sensors stayed within 0.2% F of each other, while the humidity readings stayed within 2.0%.
At first I was concerned by the lack of consistency between the sensors. But based on your literature, which states a temperature accuracy of +/- 0.5% F and a humidity accuracy of +/- 3%, it appears that all three units are “within specifications.”
Am I interpreting these figures correctly? Thanks.
P.S. I love the crisp, clear displays and the fact that they just sip battery power!
Posted: 27.02.2024 14:44
Yes, you are interpreting them correctly.
Think of the accuracy as an upper and lower bound of the shown value, there the real value can be found. When you have 2 sensors where these accuracy "bands" overlap, the actual real values can be found there.
