Base Station's Firmware Change Log
Posted: 30.03.2023 11:14
Modified: 20.10.2026 15:54
v4.12.16 - August 19th, 2026
System
- Critical firmware auto-update fix
v4.11.16 - April 14th, 2026
System
- Fixed the usage of apostrophes in the base station "Name" field
v4.11.15 - March 25th, 2026
Aranet Cloud
- Data upload optimization
Integrations
- BACnet IP stability improvement
v4.11.9 - January 5th, 2026
Sensors
* Weight sum virtual sensor reintroduced
Integrations
* MQTT - Weight sum virtual sensor support
* Bacnet, InfluxDB - "Sensor ID" and "Sensor Type" fields addedv4.10.12 changelog - November 27th,2025
Integrations:
* Modbus TCP/IP - fixed address offsets for the metrics
* Notification delays affects all integrations alarms
v4.9.9 - July 3rd, 2025
Sensors:- Aranet Light Spectrum sensor support
Graph:
- Save manual graph min/max limits in URL rather than browser local storage
Aranet Cloud:
- Cloud management
* Implemented remote reboot
* Implemented remote developer diagnostics file download
v4.8.4 - March 24th, 2025
Integrations:- Modbus TCP/IP - added Discrete Input registers for measurement threshold alarm states
- MQTT - Application-Layer Protocol Negotiation support
v4.7.19 - February 6th, 2025
System:- Added network and Aranet Cloud status indicators to the toolbar
Integrations:
- InfluxDB v2 support
Aranet Cloud:
- Management license support
v4.7.15 - January 9th, 2024
Aranet Cloud:- Base provisioning credential generation fix
v4.7.12 - December 12th, 2024
Integrations:- BACnet: resolves the issue of Aranet BACnet IP custom unit IDs introduced in v4.7.2, which can be incompatible with some BACnet clients.
v4.7.2 - November 25th, 2024
Sensors:- Radon Plus Pro support
System:
- Korean region support
Integrations:
- MQTT Last Will and Testament (LWT) messaging support
v4.6.4 - October 15, 2024
Sensors:- 4xT-probe sensor support
- T/RH Mini support
- Terralink transmitter support
Integrations:
- MQTT (Sensor Management) delete process now has additional topics: "pending" and "status"
- Fixed sensor data reception delay when low on free storage space
Networking:
- LTE connection stability improvement
v4.5.3 - August 14, 2024
Integrations:- Modbus - added option to change Unit ID (or Device ID)
- Modbus - additional field "address" added for the measurement object in auto-generated registry mapping file
- BACnet - added option to filter inbound requests by using IP address filter
Aranet Cloud:
- Cloud-connected base station functionality added
v4.4.4 - July 18, 2024
New feature:- Pulse counter conversion offset - possibility to input the current meter value to apply an offset to the converted value
Improvements:
- Minor changes in BACnet EDE file content
v4.3.2 - April 11, 2024
Integrations:- Modbus auto-generated JSON file now contains sensor "name" and "group name" info
- MQTT integration compatibility with Azure Event Grid
Networking:
- Added network interface failover in case of lost connectivity
LTE:
- Blocked SIM PIN recovery with PUK code added
v4.2.5 - March 12, 2024
Integrations:- Derived measurement dimension and unit configuration is passed to all Integrations cache and updated on user-initiated sensor configuration changes
- MQTT "name" field issue eliminated
LTE (Aranet PRO Plus LTE base only):
- Modem management improvement
WebGUI:
- A Few User Interface page's esthetics change
v4.1.3 - December 14, 2023
Cloud base management- Support for remote sensor pairing from Aranet Cloud
- Block Web UI while the management session is active
MQTT:
- Allow leading forward-slash ("/") in root topic
Licenses:
- License slots increased from 5 to 10
- The integration license's timer is paused when integration is disabled
Known issue:
! Internet connection is not switching to LTE automatically when an existing WiFi or Ethernet configured connection drops.
v4.0.2 - October 10, 2023
Soil moisture sensors:- Use improved Hilhorst pore water electric conductivity preset by default for newly paired sensors.
LTE:
- Roaming support
- Improved stability
BACnet:
- After the system boots, the 'Reliability' property for measurement objects is set to 'Communication failure' until measurements have been received.
Known issue:
! Internet connection is not switching to LTE automatically when existing WiFi or Ethernet configured connection drops.
v4.0.0 - August 28, 2023- Base firmware update initiation from Aranet Cloud
v3.5.3 - August 18, 2023- BACnet IP integration added
Known issue:
v3.4.7 - July 31, 2023- T, PEC & VWC thresholds added to soil moisture sensors.
- Sensor pairing stability improvements.
- MQTT - added Keep alive configuration setting.
- AS1 (Japan) region support added.
- LTE modem status displayed in web UI
Known issue:
v3.3.6 - April 14, 2023LTE:
- Modbus * Fix for received message counter used for server activity diagnostics
v3.3.4 - March 15, 2023Licences:
- Multiple simultaneously active timed licences are now supported
MQTT:
- Root topic length limit raised to 100 characters
Aranet Cloud:
- Reduced traffic: as few as 1 GB monthly traffic for the base station with 50 Aranet4 sensors paired at 1 min. interval
v3.2.5 - January 11, 2023- Hardware WatchDog improvements
v3.2.4 - November 24, 2022Sensors:
- New sensors support
* CO2 IP20 sensor
* WET150 Transmitter
* Teros 12 Transmitter - Soil sensor "Cocos or peat" and "Soilless media" profiles added to VWC sensor configuration
Modbus TCP:
- Added Read sensor's loss status (RSSI alarm) using Modbus function "Read Input Status" (code: 2) from Discrete inputs.
- Minor bugs fixed
v3.1.7 - August 15, 2022- Fix measurement conversion configuration display
v3.1.6 - July 21, 2022MQTT:
- JSON messaging profile now contains sensor alarms
Modbus TCP:
- Basic Modbus TCP protocol support (requires licence)
Sensors:
- PM sensor
* Added PM1 metric to sensor list view and added PM1 thresholds. - VWC, EC, T sensor
* Updated VWC formula, introduced new presets, PEC formula configuration and comment field for custom presets.
Backup:
- Backup will now be automatically uploaded to the Aranet Cloud (for registered devices). This upload can also be performed manually from the System/Backup page.
v3.1.6 Breaking changes:
- PIN disable removed from System/Notifications/SMS page
v3.0.7- Semi-automatic firmware upgrade functionality
MQTT:
- Support for mains-powered sensors
* 0-10V transmitter
* 4-20mA transmitter - Support for particulate matter sensor
Measurement conversion:
- Added radioactivity and PPFD to convertible metrics
v2.7.X- Infrared thermometer support
- Sensor continuous pairing
- Asia region support
v2.7.X Breaking changes:
- MQTT measurement topic name changes:
* weight_raw → weightraw
* motor_seconds_period → motorseconds
* motor_seconds_cumulative → motorsecondscumulative
* derived_cpp → derivedp
* derived_cpc → derivedpc - Other MQTT-related changes:
* "packetslost" alarm now is being sent as a retained message
v2.6.X- Improved Aranet Cloud upload performance and stability
- DHCP Static IP fallback option added
MQTT:
- Sensor group name and id fields are now sent via MQTT
New sensor support:
- S5V18 Dry Contact Hour Meter
v2.5.X- Simplified menu structure
- Product number is shown in sensor card
- Russian region bases now support 1min TX interval
MQTT:
- Connection support with Amazon Web Services (AWS IoT Core);
- Measurement delivery format customized for Microsoft Azure;
- Sensor's product number is being sent to the MQTT broker;
- "Packetslost" alarm will now be re-sent after changes to MQTT configuration;
- Sensor names will now be sent right after changes to the sensor or MQTT configuration;
- In case of sensor removal, all retained topics like name and "Packetslost" alarm will be cleared on the broker side;
- 3d party Client certificate file upload available for more secure TLS connection establishment to MQTT broker;
New sensor support:
- CO sensor
- AC hour meter
v2.5.X Breaking changes:
- The MQTT CA certificate will need to be re-uploaded after upgrading from a lower firmware version
v2.4.X- Added MQTT licensing
- Various bug fixes and performance improvements
v2.3.X- Added licensing support
v2.2.X- Added support for:
* Medical thermometer
* Various gas sensors (NH3/NO2/O2) - Added selectable differential pressure units (Pa/mbar/mmH2O)
- Added pressure unit (atm)
- Linearised battery charge percentage indication
