Can I receive data from one Aranet sensor on multiple Aranet PRO base stations?
Posted: 06.02.2021 23:22
Modified: 20.10.2026 15:16
Yes, it is possible.
This can be done by pairing all necessary sensors on one Aranet PRO base station and exporting configuration backup. Then such backup configuration can be imported on an unlimited number of other Aranet PRO base stations copying/cloning the same configuration on them as present on the initial Aranet PRO base station. All cloned Aranet PRO base stations will record the data from the same Aranet sensors when they will be in the reception range of these sensors.
First you should navigate to the Base station User Interface and from there go to SYSTEM (1) -> BACKUP (2) -> EXPORT BACKUP (3). And you will get the file (4), then it should be imported into new base station. This can be done similar way: SYSTEM -> BACKUP -> IMPORT BACKUP.
Only NOTE that when the backup is imported, then the previous existing configuration on the Aranet PRO base station (if any) is deleted and replaced with the configuration of the Aranet PRO Base Station that you downloaded the backup file.
neillaidlaw
Posted: 28.04.2026 13:34
Good afternoon,
I have 2 base stations each with a licence for 50 sensors. As the site is large i would like to clone my base station config over the 2 stations which would take me to 65 sensors in total. Does my 1 x licence for 50 sensors on each base station (100 total over the 2 base stations) cover me to do this as at the moment i can only learn in 50 sensors before cloning and that is not enough. Thank you
Posted: 29.04.2026 05:17
No, if you want to fully clone the base station, then you would have to upgrade the sensor license on the base station to 100 sensors. By uploading a backup to the base station, it overwrites the pairing data of the base station, as well as the settings. So you need to pair all of the sensors to 1 base station and then download the backup to clone the base station.
