sensor name and sensor group not updated in MQTT message
jjo
Posted: 22.01.2024 14:24
Modified: 20.10.2026 16:45
When I update Sensor Name and/or Group this change is not represented in the MQTT messages I receive.
I do receive a new MQTT message when I change the name and/or group in the Aranet PRO ui, and de name and/or group are updated there. However the value of the MQTT messages doesn't reflect the updated values.When I use mqtt-cli to subscribe on all Aranet topics I see something like this after I update (Note that sensor names are identical to their ID's):
mqtt sub --topic Aranet/# --showTopicsAranet/\<base serial number\>/sensors/\<sensorID\>/name: \<sensorID\>
Aranet/\<base serial number\>/sensors/\<sensorID\>/productNumber: TDSPAR02
Aranet/\<base serial number\>/sensors/\<sensorID\>/productNumber: TDSPT509
Aranet/\<sensorID\>/name: Aranet-\<ID\>
I updated the firmware recently from v2.7.12 to v4.1.3 and we are running WR12 hardware on a product with product code: TDSBWPA1.050
Posted: 23.01.2024 13:57
After an investigation this has been discovered as an issue with the v4.1.3 firmware. We are sorry for the inconvenience. You can either wait for the next firmware version or contact [email protected] and ask for a firmware downgrade due to MQTT problems.
jjo
Posted: 23.01.2024 14:22
Thanks, I will do that.
