What could be practical appliance of Expert virtual sensor in Aranet cloud?
Posted: 14.06.2021 07:36
Modified: 10.11.2026 20:31
You can select an Expert template when creating a Virtual sensor in the Aranet cloud:
This formula represents calculations to be made with measured data of up to 10 sensors. All input sensors must have the same metric. The result of calculations will have the same metric as input sensors.
Formula variables are:
- x(t) - input sensors measurement, unit is defined by sensor's configuration;
- k - slope, a real number in the range of -1e+10 to 1e+10;
- b - offset, the same unit as input sensor;
- n - number of sensors, min = 1, max = 10;
- m - normalizing factor, a real number in the range of -1e+10 to 1e+10, must not be equal to 0.
Indeed, Offset, Average and Sum are special cases of Expert formula.
More information regarding usage and Expert Virtual sensor is available here: Expert Virtual Sensor
erensts
Posted: 09.07.2021 12:39
As outdoors is very hot and I do not have aircon, I have created a virtual sensor that measures delta between indoor and outdoor temperature and if it goes below or above the thresholds I get a notification to open or close the window to preserve room temperature as low as possible.
Virtual sensor to create delta - now outdoors is close to 34 degrees Celsius hot and the room is 28.9, so I use -1 as a multiplier to calculate the delta.
The second step is Alarm based on the virtual sensor:
Result - if the outside is hotter than indoors at least 2 degrees I am notified to close the window and preserve the room in mild condition. when during evening temperature drops below room temperature I get notifications to open the window and cool the room a natural way.
And this is how do I see it in notifications - Alarm is active as delta is above 2 degrees
niels
Posted: 12.01.2024 08:23
The constraint that the formula must yield the same metric as the sensors seems arbitrary. Examples:
- I could use your infrared sensor to calculate temperature; that would tranform W/m2 into Celcius.
- I could use a multispectal light sensor (hacking in a transmitter of yours for each spectral channel) to estimate the biomass of a crop (turning W/m2 into kg/m2).
- I could use your UV sensor to inform about the recommended maximum time of unprotected exposure (turning W/m2 into hours and minutes).
Why not provide a simple text box to type in the metric resulting from the formula? That's even way easier to implement than the formula itself!
