Aranet4 integration with Home Assistant
admin
Posted: 09.12.2022 15:29
Modified: 22.11.2026 12:30
SEE ARANET HELP FOR UPDATED VERSION!
Aranet4 devices are now supported by Home Assistant Home Assistant (home-assistant.io) smart home automation platform.To enable Aranet4 integration please ensure that you have Aranet4 device with firmware version 1.2.0 or newer and Home Assistant version 2022.12 or newer and Bluetooth capability.
Aranet 4 CO2 sensor review and Home Assistant integration - YouTube
Initial configuration seteps:
- Before start using integration please configure Aranet4 device using Aranet4 App - enable Smart Home Integration in Aranet4 App device settings
2. Download and set up Home assistant Aranet integration - Please read the instructions for setting up Aranet Integration on Home Assistant
Good to know:
Aranet4 is using BLE (Bluetooth Low Energy) communication protocol which has limited range. Please ensure a close distance between Aranet4 and Home Assistant hdevice to avoid connectivity issues. To improve connectivity you can select Extended blouetooth range option in Aranet4 App device settings.
sruslanas
Posted: 08.06.2023 09:21
You can add, but several minutes after it becomes Unavailable.
Posted: 08.06.2023 11:00
Dear customer,
For further troubleshooting please send a detailed description of the faced issue to [email protected]
bimbam
Posted: 26.07.2024 12:13
Modified: 26.07.2024 12:15
I just integrated Aranet 4 successfully (finally) in Home Assistant running on a Raspberry 4.
Some notes:
Raspberry 4 bluetooth range is poor. Build in an Aluminum case it was about 0,5 m, without case about 4 m.
So for the setup, bring the Aranet 4 very close to the HA-device.
If you use different hardware than Raspi 4, BT-range might be better, but if you use the Aranet 4 far from the HA-device, you may need a bluetooth proxy.
There are several ways to do this, I testetd these two successfully:
1. Set up a bluetooth proxy using an ESP32. It's quiet easy. There are tutorials on Youtube.2. If you got one of the 2nd Gen Shelly devices (with a "Plus" in the name), they can easily be made a proxy by activating the Bluetooth Scan Mode in the Shelly integration configuration. Or just buy a "Shelly Plus Plug S", plug it in and your proxy ist ready to go.
Hope this will help. :-)
jung
Posted: 08.07.2025 10:11
If I have a Aranet Pro Radon Sensor and a LoRa Module connected to my Raspberry Pi, can I connect the sensor to Homeassistant via LoRa?
Posted: 08.07.2025 13:07
No, Aranet uses a propriatery, modified LoRa protocol meant only to connect Aranet devices. You won't be able to connect to an Aranet sensor that way. You can however connect through Bluetooth with the sensor if you first enable "Smart Home integration" in the Aranet Home app.jung
Posted: 08.07.2025 13:32
ok, thanks. so I need the aranet pro basestation, I guess.
