Calibrating atmospheric pressure
mfkp
Posted: 18.07.2022 21:41
Modified: 22.11.2026 12:30
The readings on my Aranet4 are not accurate for air pressure. The unit is currently showing 27.67 inHg, while my weather station (and the local airport ATIS) are both showing 29.98 inHg.
Is there any way to calibrate the unit?
Posted: 19.07.2022 06:54
Aranet4 atmospheric pressure sensor can't be calibrated. Would you please send the photos or screenshots of Aranet4 and your weather station atmospheric pressure data to [email protected] for troubleshooting?
seathg
Posted: 05.09.2022 05:30
There seems to be a disconnect in the understanding of "barometric pressure". The pressure we all refer to when discussing the weather. This "pressure" is normalized to sea level. If you are not at sea level then you must add a correction factor to the air pressure that is measured.
If the Aranet4 is reading air pressure accuratly then an altitude correction must be done to give "barometric pressure". Without this correction the number on the app is the air pressure.
Using my iphone as a reference, both the iphone and the Aranet4 read within 0.06 in. of mercury air pressure. The iphone then corrects for the altitude of your location to give "barometric pressure", in good agreement with local weather stations. This is not possible with the Aranet4, so the number displayed is absolute "air pressure", uncorrected to give "barometric pressure".
If the app allowed the user to enter an altitude, then the pressure reading could be corrected.
chris_in_texas
Posted: 01.08.2023 03:39
I got in to Estes Park from Texas and my pressure now reads 22.94". I wish you could add compensation factor to correct this.
chris_in_texas
Posted: 01.08.2023 03:40
Posted: 01.08.2023 10:26
Modified: 01.08.2023 10:29
Hi Chris,
Please check your email.
bimbam
Posted: 26.07.2024 12:55
I found that air pressure is reported amazingly accurate.
Current air pressure in my region is 1013 hPa according to a weather service and Aranet 4 shows on the app 997 hPa.As I'm located about 136 m above sea level, I have to substract 136 m x 0,125 hPa/m = 17 hPa from 1013 hPa, resulting in 996 hPa.
So 996 hPa vs. 997 hPa, that is a variance of 0,1%.
