How to get the latest firmware version for the Aranet PRO base station?
Posted: 19.01.2021 22:59
Modified: 26.04.2024 08:17
You can visit https://aranet.com/downloads and you will be able to find and download the latest firmware version. This file should be unzipped and then uploaded in the format AranetProUpgrade-vX.X.X.tar.gz to the Aranet PRO base station. Don't rename the firmware file!
Firmware upgrading instructions
1. Download the firmware zip-packed archive file at https://aranet.com/downloads to your computer.
2. Unpack zip archive to the folder you are able to access.
Don't change the file name!
3. Turn On Aranet Pro base and wait for the system to load.
4. Log in to Aranet Pro web-interface as the user having Administrator rights.
5. Navigate to SYSTEM menu and select FIRMWARE tab.
6. Click on CHOSE FIRMWARE FILE button.
7. In the opened window find the folder where you unpacked the firmware file, select this file and click "Open" button.
8. Enter Administrator password when asked and press OK.
9. File uploading process will start.
10. When uploading and installing process is finished, notification message is displayed and the device reboots.
11. Wait about 2 minutes and reload the browser window.
12. Navigate to SYSTEM menu, FIRMWARE tab, and check the firmware version.*****************************
TroubleshootingIf firmware upgrade fails, check the firmware file name and extention:
- File name must be "AranetProUpgrade-vX.X.X", where X.X.X is the version number;
- File extension must be ".tar.gz".
Some archiver software tends to unpack all available archive levels of the file. Switch off this archiver's feature to leave the archived .gz file untouched.
For example, macOS users should deselect "Keep expanding if possible" feature of the built-in archiver.If upgrading still fails, contact support@aranet.com.
