How to share CO2 measurements data with public
Posted: 07.12.2021 09:28
Modified: 02.12.2023 05:31
Sharing CO2 sensor measurements with the public is possible when Aranet Cloud Public monitors service license is purchased. Then clients can share any of their CO2 sensors data by using CO2 monitor dashboard tile. Link to the monitor can be generated and shared with the public. Access to monitor does not acquire authentification and data can be observed in any Internet browser (We recommend using the latest versions of Chrome, Safari, and Edge).
To create new CO2 monitor tile
1. Login to your Aranet Cloud organization and navigate to MONITORING menu:
MONITORS tab will present the list of existing tiles.
2. Press + NEW MONITOR button, a new window will open:
3. Click to Source and select needed sensor from drop-down list:
Clicking on
button will show information about the selected sensor:
- Sensor name
- Sensor type
- sensor location
- sensor tags
Click on selected sensor to return to previous view
4. Now you can review and adjust the monitor view:
You can change the monitor tile name (1). By default, the name of the sensor is used.
Monitor preview (2): the background color and emoticon are corresponding to tile configurations settings which are described here. The current date and time, and CO2 value are shown. The view can be supplemented with historical measurings chart - Chart period is selectable on the right side (3). F.e. 24-hour period chart is selected:
Here you also can decide about the visibility of the tile monitor to the public (4).
When you finish with adjustments, press CREATE button. You will be returned to MONITORING menu view with new monitor appearing in the list:
You can add monitors to the active Aranet Cloud dashboard (1) by one or all at once marking the corresponding checkbox.
And note the HTML page link generated (2). This link can be copied to the clipboard by pressing onbutton and then shared with the public. You can check the link by clicking on it. this will open created tile monitor in your browser.
If you decide to stop sharing the tile with the public, you can edit the monitor by clicking
button and setting Sharable link to Hidden (1):
You can also Regenerate the link (2) and copy it to clipboard
. Don't forget to save your changes (3). If you don't need this monitor anymore, you can delete it by pressing DELETE button.
